Posted by James Williams on January 03, 2009 at 13:07:38 from (65.73.216.19):
In Reply to: 460 problems posted by Nebraska Kirk on January 03, 2009 at 08:15:56:
Kirk,Ive seen tractors that has been sitting a long time have very little compression due to dry cylinders,Pour some oil into the cylinders and crank the motor over with the plugs out,then install the plugs and try again
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
