Posted by El Toro on January 03, 2009 at 17:24:17 from (64.12.116.73):
In Reply to: Re: 460 problems posted by Nebraska Kirk on January 03, 2009 at 16:07:41:
If the suction doesn't improve with a new gasket. Do a compression check and compare the readings. Squirt a good bit of engine oil into the cylinders and crank over the engine a few revolutions then do a compression check. The rings may be stuck if it hasn't been run lately. I would check the valve clearances too, to make sure they're not set too tight. Hal PS: If it still has low vacuum I would pull it and see if it will start.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
