Posted by Nebraska Kirk on January 03, 2009 at 16:07:41 from (207.91.4.223):
In Reply to: 460 problems posted by Nebraska Kirk on January 03, 2009 at 08:15:56:
James W, I had a little diesel in the cylinders as the engine was slightly stuck, so that should take care of the lubrication.
El Toro, I tried your suggestion and I could feel very little suction.
I pulled the manifold off and the gasket came off in two pieces, it looked like it was sealing around all the holes ok, but I will get a new one. Another thing, exhaust was leaking from where the two halves of the manifold join together, so I am attempting to take it apart and replace that gasket, so far I have not had any luck. I torched the heads off the four bolts that hold the two halves together, then used a cold chisel & hammer to try splitting them apart. It won't budge, I quit for today, will try again another day.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
