Re: Starter for an F14
Posted by Animal on January 03, 2009 at 17:55:25 from (172.165.181.193):
In Reply to: Starter for an F14 posted by Doug Steinbach on January 03, 2009 at 17:47:53:
Doug, I have installed lots of starters on F12 amd F20s, if you want it to start and are not worried about factory the best way I have found to do it is to use a flex plate off an S 10 chevy truck bolt it and center it on the engine transmission coupling fabricate a mount from the trans, or bell houseing depending on your preferance and light the old girl up!
