Posted by mkirsch on January 05, 2009 at 05:33:22 from (64.80.108.55):
In Reply to: More H questions posted by Wardner on January 05, 2009 at 05:27:12:
Steering play is usually a combination of things. Some gear wear, some slop in between the sector gear and the vertical shaft, and some slop in the bushings on the vertical shaft.
Sometimes a layer or two of beer can tin between the vertical shaft and sector gear will tighten it up acceptably. Sometimes you need to drop the vertical shaft out and replace the bushings. Not much you can do about the gears because used ones will be just as worn and new ones will cost more than you paid for the entire tractor. A little slop is normal, as long as it doesn't shimmy down the road.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
