Re: Farmall H Not Starting
Posted by GordoSD on January 05, 2009 at 06:40:30 from (66.115.200.140):
In Reply to: Farmall H Not Starting posted by Phil in the hill on January 05, 2009 at 06:28:09:
Remove the battery. charge it on 6v, 10 amps for 4 to 6 hours. Then take it to a shop and have it tested. Replace if necassary.
Remove ground cable and sand point of contact and cable end shiney. Claean battery end bright and shiney.
Look closely at your starter cable. How large is it? It MUST be a tractor cable , 0 or 00 in diameter. Replace as necessary.
Post back after you go through these steps.
Also check the archives. This comes up about every 10 days on this board.
Gordo
Gordo
