Re: Farmall H Not Starting
Posted by Bob Kerr on January 06, 2009 at 11:50:22 from (63.134.174.179):
In Reply to: Re: Farmall H Not Starting posted by GordoSD on January 05, 2009 at 06:40:30:
Just a long shot here but how did you clean the valves? If you shot a bunch of engine degreaser on them around the stems it may be possible that enough got in a cyl to lock up a piston. I guess you will see when you pull the plugs out like the others mentioned. As far as batt cables go, do like was mentioned with heavy cables and be sure ALL connections are very clean! 6v is very picky about clean connections. I do mine every year whether they need it or not during my "spring tune and clean and check"
