Help Batteries on a 1968 IH 3444
Posted by M Miller on January 06, 2009 at 06:34:30 from (76.233.38.35):
This tractor had one 12 volt battery & would eat them up even after overhaul. Start good when weather is warm but when it gets to 35 deg F have to give it a shot of starting fluid. I change to two 6 volt batteries in series & this seamed to help but not the cure. If I change to two 12 volt batteries in parallel would this help more & what else would be needed to do this? I change the generator to a alternator some time ago & that helped quite a bit.
Thk's for the help
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
