Re: Help Batteries on a 1968 IH 3444
Posted by JimB2 on January 06, 2009 at 16:46:28 from (99.241.179.24):
In Reply to: Help Batteries on a 1968 IH 3444 posted by M Miller on January 06, 2009 at 06:34:30:
Hi, from 1962 thru 1991 we had B414, 434, and 384 all with BD154 on our family farm. The only way to start the BD154 when temp drops below -5F was with coolant heater. You can put an inline heater in the lower rad hose easily. Plug heater in for 1 hour and your good to go. The BD154 is very hard on batteries for two reasons: it has a 22:1 compression ratio so requires lots of amps from batteries for glow plugs and for starter to roll engine, next reason is engine has lots of vibrations and causes battery plates to fail.
When we worked in our wood lot in the winter with the B414, we either had to drive it a mile and plug it in at an uncle's or leave in on a hill. If we left on a hill we would heat the glow plugs then let roll down the hill in 4th Hi, hit the starter and pop the clutch at the same time and it would always start even in -25F weather. Only danger was a deep snow fall and we would have to shovel some of the hill but usually if there was a pending snow fall we would drive it to my uncle's place and plug in the heater.
JimB
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
