modifying a J 4 magneto to use an external battery
Posted by e. chrisjensen on January 06, 2009 at 20:51:07 from (64.119.2.2):
Has anybody tried to modify a J 4 magneto on a farmall cub to use a battery? Seems that one could use a battery, external coil, possibly change the condenser to an external condenser compatible with the 6 or 12 volt coil and disconnect the coil inside the magneto? Wanted to try this as a temporary fix.
I did this on a small Tecumseh motor that had a magneto ignition under the flywheel. Used an external coil with internal resistance, external condenser, and disconnected the magneto coil which was broken.
