Re: modifying a J 4 magneto to use an external battery
Posted by El Toro on January 07, 2009 at 10:29:58 from (64.12.116.73):
In Reply to: modifying a J 4 magneto to use an external battery posted by e. chrisjensen on January 06, 2009 at 20:51:07:
third party image
Here's a pic of that setup on an H4 mag, your J4 should be similar. You need to disconnect the wire from the mag's coil to the points. The grounding wire needs to be disconnected from the mag too. You will need an ignition switch with battery voltage fed to the switch and from the switch to your auto type coil. Then from the coil to the points. Hal
