Re: '41 H seat deck
Posted by Andy Motteberg on January 08, 2009 at 12:05:20 from (4.143.216.197):
In Reply to: '41 H seat deck posted by FarrviewWest on January 08, 2009 at 11:42:53:
The original seat frame looks like a curved pipe, the pipe is attached to the mounting bracket bolted on top the transmission housing with a spring on it. The seat pan is on the other end on the pipe with a hinge to flip the seat over when it is not in use and some have a tin toolbox bolted onto the pipe.
