'41 H seat deck
Posted by FarrviewWest on January 08, 2009 at 11:42:53 from (165.206.209.230):
I am new to this. The bolt pattern on my transmission cover/deck has a different bolt pattern than what I've typically seen. Does anyone know which seat assembly was originally on this tractor? (S/N FBH-53953)
I've replaced the seat assembly with the mid-mounted shock seat assembly, but I can only bolt it to the front bolt locations.
Thank-you ion advance for any ideas you might have!
