Re: I got the 300 running
Posted by Blackland Dan on January 08, 2009 at 15:21:53 from (67.142.130.18):
In Reply to: Re: I got the 300 running posted by Pete 23 on January 07, 2009 at 19:42:48:
Pete, I removed the cover plate and turned the engine over and the clutch did turn. I started it up and the clutch still turns whether in hi or low, in gear or not and clutch in or out. With engine running, the clutch turns smoothly and doesn't make any unusual noise. With the engine stopped, I felt the clutch and it has free travel rotating about 1-1/2" either way. I can also move it up and down slightly. At one time, I put it in gear and released the clutch and it started to move. I put it in neutral to get down and remove some stuff from under the tractor and when I tried it again, it wouldn't move.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
