Posted by jdemaris on January 09, 2009 at 17:46:04 from (72.171.0.148):
In Reply to: B275 electrical posted by howling wind wayne on January 09, 2009 at 14:08:06:
I've got four B-275s, all now 12 volt negative ground with Delco or Hitachi alternators. So, if you get stuck and have any specific questions - I'll try to answer. Also have a 3414 backhoe that is basically the same as a B-275.
If you plan on keeping that Lucas generator, you'll need a different regulator. It' not worth it. You can install a negative-ground Hitachi or Delco alternator much cheaper and get a lot more charging current for running lights, etc.
Why do you want to change the polarity? There's no gain, either way - just happens to be a necessity when installing an alternator.
As to the clutch? It's a pretty rugged seup and it would be rare when all needs replacement. I've put new clutches in many. Usually two new clutch disks, a throwout bearing, and - sometimes new clutch fingers - and you'll be fine. The new fingers are still available from IH, over the counter.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
