Re: converting H to 3point hitch W /hydraulics
Posted by john d on January 10, 2009 at 14:02:23 from (69.130.165.52):
In Reply to: converting H to 3point hitch W /hydraulics posted by welderdave on January 10, 2009 at 13:41:14:
The front hydraulic outlet on the left side gives the same flow and pressure as the one on the right side. The rear port on the left side is a "delayed" port that was timed to lift the rear gang of the cultivators at the same place the front ones were lifted when traveling in 4th gear. We used to use the same setup on the M to raise the planter with the rear port at the same place we picked up the harrow mounted between the tractor and planter.
I think the bracket under the pump was used in mounting a sickle bar mower that ran ahead of the rear wheel. Not certain of that.
