Re: How to time a Distributor?
Posted by ScottyHOMEy on January 11, 2009 at 07:25:01 from (70.105.226.211):
In Reply to: Re: How to time a Distributor? posted by Garry in TENN on January 10, 2009 at 21:39:41:
Somebody before you thinks like I do. I've painted that mark with a stripe on every flywheel I've been able to get to. At teh very least a dab of paint through the handhole if I could find the mark in all the grime and dark.
As for the timing mark, it is on the rear (inside) of the not-quite-half-moon cover on the front of the torque tube, under the rear of the engine. some had a very handsome steel pointer, others had just a raised nub in the casting. If yours has the latter it couldn't hurt to dab some white paint on that, too. Easy, that cover is only held on with two bolts and will slip right out. As Gene said, the mark on your flywheel will be at the bottom when the motor is at TDC.
