Re: Pullin' the Pully......Super A
Posted by Wild Bill Caldwell on January 11, 2009 at 16:22:42 from (67.33.110.139):
In Reply to: Pullin' the Pully......Super A posted by Wild Bill Caldwell on January 11, 2009 at 14:39:20:
bc..... I know what You advise will work, around No. La. in the old days it was called a shrink fit, I've done bearin's and sleeves like that many times....also have had a few get almost where they needed to be ,....then stop....tighter than "HELL" and a half twist more.
Jim....I agree with cleanin up and polishin', I'll use a squirt of Kroil, build the plate to hold the crank forward and use a bolt in the crank.....nothing like overdoin' it
Wild Bill
