Re: IHC 57 .Elec, problem
Posted by Janicholson on January 11, 2009 at 17:05:05 from (68.112.156.69):
In Reply to: IHC 57 .Elec, problem posted by Wylie on January 11, 2009 at 16:15:52:
If the amp guage is still attached in the same polarity as it was when it was 6v. The gauge reads backwards. Turn on the ignition and carefully watsh the gauge if it moves to a tiny bit of charge, it is backwards. If the lights work, turning them on (with engine off) will also show charge with the gauge backwards. The proper wiring depends on which alternator it has, out of what vehicle. so giving directions must wait until we get that info. We can get through all types, we just cant give info that could let the smoke out of components. We also need to know which way the battery is installed. (which post is ground) JimN
