Re: Farmall 140 tractor
Posted by Janicholson on January 11, 2009 at 17:14:17 from (68.112.156.69):
In Reply to: Farmall 140 tractor posted by d bridgers on January 11, 2009 at 17:04:13:
The engine number is on the block on a raised pad near #1 plug. The numbers (I believe) are not in sequence with serial # of tractor. Casting codes are the best they consist of MM+DD+Letter with the plus marks as screw heads that held in the date plate on the patterns. The Letter will be a single alphabet letter. find three or so on castings to help us id the date of production (which is always a bit later than the casting date. JimN
