Re: Pullin' the Pully......Super A
Posted by mattofvinings on January 13, 2009 at 15:57:49 from (67.142.161.34):
In Reply to: Pullin' the Pully......Super A posted by Dave Koenigsfeld on January 11, 2009 at 14:39:20:
Gene Bender said: (quoted from post at 12:31:36 01/12/09) So what will the heat do to a new seal.
The 200F mentioned is a normal engine temp.
300F oil sump would be near meltdown but it should still survive.
I would personally not hesitate to use 200-300F...the pulley will cool some by the time you get it from the oven and positioned/ready to press.
IMHO a person is cheating themselves by purposefully loosening the fit of the crank pulley on any engine as I personally believe they were designed to be tight. While the engine rotation appears smooth it is jagged as can be from a torque impulse standpoint.
Also consider the cost of having a pulley get "loose" and start knocking around into the key....which wallers the keyway by the time it is discovered...which means get a new crankshaft and do a major engine teardown. Not worth it in my opinion.
This post was edited by mattofvinings at 16:06:12 01/13/09.
