Gene Bender said: (quoted from post at 04:04:03 01/13/09) Putting some ice on the shaft wont hurt a bit as metal expands something like 6 to the 7th power per inch per degree.
Not quite an exponential power, but the linear expansion would be roughly .000006inch per inch size for every degree F. Area around .000012/square inch/degreeF. Alway wise to double check my math though! :lol:
Small numbers no doubt, but [note math disclaimer!] a 1.5" shaft will be .001 larger with 100degrees F increase in temp; enough to go from a press fit to a slip fit! Cooling the shaft and doing 200 on the pulley, probably gets you to 150 difference, better yet!
A parallel question I have: anyone use anti-seize on press fits? It seems like an oxymoron, but I've found grease [pretty crusty after 70-80 years!] often enough under press fits, and wondered it anti-seize would be good for both assembly and [if I ever need to :shock: ] disassembly without affecting the fit (I don't see why it should hurt a good fit, but never tried it).
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
