Posted by Janicholson on January 13, 2009 at 17:17:51 from (64.83.227.252):
In Reply to: Re: MW 9 speed posted by Wardner on January 13, 2009 at 16:07:57:
Take a M7W pinion attached hand clutch. It has a pinion gear and carrier that replaces the IH unit. These have a shaft that is connected to the differential side gear, this shaft is running in the center of the pinion, and extends to the place where the brake is usually located. There are drive and driven disks on the outside with a lever over center clutch that controls the power to the bull pinion. If a person made a gear change for that set of splines on the outside, and set it up to make a reduction between the pinion and the drive "shaft" it would allow a reduction in the entire system. It would not be for field use. it would be for pulling. The only difficulty is it would be outside the tractor, and unless shrouded it would be visible. Hard to make? Shre. Using a short track quick change gear set and adapter would be a far shorter route than reengineering the whole thing. JimN
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
