Farmall A Piston Question
Posted by Mr. Jeffries on January 16, 2009 at 12:14:36 from (204.184.253.1):
Hello,
I have a student working on a Farmall A tractor. He ordered a replacement piston as he had one that was cracked pretty badly. The tractor has stepped head pistons in it with 3 compression rings and 1 oil ring.
The replacement piston that we ordered seems to be the correct size (bore and pin) but it only has 2 compression ring grooves and 1 oil ring.
Will this work on in this application? I"m guessing the weight difference would be minimal.
Thanks for any help,
Jared Jeffries
Jasper FFA Advisor
