Weigh the piston assembly if you"re worried. The 4 ring design is "early" design, the 3 ring is "late" design. Later rings will be slightly different than early but 3 ring is more current. piston skirt length should be close to same, wrist pin to top of piston should be same, oil control ring may be wider, multipiece insted of plain or narow space multipiece. Ford tractors have same situation, balance problems with mixed 3/4 ring pistons is not noticable. 3 ring piston might have a little more blowby on worn cylinder but pressure of 120 or so is not going to be much. Diesel pistons are more of a concern- the 4 rings are needed for 250+ pound cylinders. RN
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
