Have to differ with you also, don't mind discussing things. I could be wrong and could learn something. I have looked at the records before and unless I missed something it showes the first tractor in jan. 52 as FBKM engine serial # being 277923 and first tractor regular gas M FBK serial # 290923. Think cotton harvestors and modified M based tractors was the only thing after the end of march 52. No regular M tractors after march. Unless I'm mistaken he said the engine # was 272809 so from past work on this I put the engine serial # 13000 higher than engine for that engine # range. I also said if engine is original to tractor. If not he will have to determan that by date codes or cast # suffixes sometimes. Here' a real tractor # 286713 engine 273713. If you notice the engine # is higher than his. For some reason the MD tractor serial numbers for start of Jan. 52 are a good bit lower than gas. 285211. I welcome anyone with a original M tractor around serial 285809 to post one serial or the other and see how many times I get the other # to check it out if you like. When you see the M numbers drop back to 3 digits in 1952, I think thats SM tractor serial numbers even though they don't show it on there.
Today's Featured Article - Antique Tractor Wiring Basics - by Curtis von Fange. One of the most neglected parts of old tractors is the wiring. After sitting in the elements for half a century or more much equipment wiring has deteriorated to sparsely covered strands of copper or other metal. Plastic insulation has cracked, mice have eaten through the older clothed style coverings and the exposed wires have reacted to winter moisture and salts by turning blue and powdery. Terminal ends have corroded, rusted or just plain evaporated away. Aged wires not only keep an engin
... [Read Article]
Latest Ad:
1953 Ford Jubilee Tractor. Last driven 5 yrs ago. Parked ever since. As is as seen
[More Ads]
