Re: IH 574 streering problem
Posted by caterpillar guy on January 19, 2009 at 18:01:51 from (64.12.116.73):
In Reply to: IH 574 streering problem posted by kdog4020 on January 19, 2009 at 17:51:28:
The brakes will probably need to be bled the bleeders near the bottom of the fuel tank on each side of the transmission lid you have to look behind the tank. The steering might be the pump. I would get the shop manual out and find the plug to check the pressure at the multiple control valve on the left side under the step. Also check fliud level for full. We have had a lot of problems with steering and brakes over the last 37 years on ours.
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
