IH 574 streering problem
Posted by kdog4020 on January 19, 2009 at 17:51:28 from (66.94.96.143):
I have a 574 utility tractor with the swing back axels the power steerning dose not work while sitting still but with movement seems to work if you turn it slowly. the 3 point works fine the brakes dont work at all the peddles go to the foor with no effort change the hydrawlic filters still works the same. if its the pump what dose that cost. or how can i check this out thanks
