engine miss
Posted by Stan Bainter on January 20, 2009 at 12:34:02 from (76.29.129.96):
After starting(crank)engine runs good for 30-45 seconds then runs rough for another 30-45 seconds then starts missing. Increasing throttle or chokimg makes no differance.No change w/adjusting mag. Removing plugs and doing compression test shows 60lbs on all 4 cyl. Have adequte fuel from pump. Carburator filter changed and screen cleaned. Plugs are new. New gas.All suggestions appreciated.
