Re: BD-154 Fuel Pump Problem( what am I missing challenge?)
Posted by Seeing Red on January 21, 2009 at 03:00:56 from (69.63.236.101):
In Reply to: Re: BD-154 Fuel Pump Problem( what am I missing challenge?) posted by BMD on January 18, 2009 at 17:22:27:
The shim got added between the pump housing and the lever. I just simply used a snap ring big enough not to fall off the lever shaft. The side that was worn was obvious when the pump was removed. I too thought the cam should be hardened enough not to let such things happen, but I realize we don"t live in a perfect world. I was surprised how much side movement there was in the lever. Maybe the mechanism was worn too much, but it works now so I will leave well enough alone.
