Apparently cam wear is a more common problem that you would every suspect. Its more likely the uneven cam wear and lateral movement in the lever add up to a lever that will not stay on the cam.
We are planning to try the shim and if no luck as "plan B" we'll convert to a electric pump as others have done.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
