Farmall H differential
Posted by t martin on January 21, 2009 at 07:28:46 from (205.213.92.64):
I have a 1943 farmall h. The transmission is mostly apart right now. I noticed that the big bevel gear on the differential is loose. You can role it forward and backward without the rest of the differential moving and you can see the bolts move when you do it. Does this just need to be tightened or is there a pin or key broke off in there some where along the way that keeps this gear from rolling? It seems that if you were to tighten it the gear would still want to role. Any thoughts?
