Re: Farmall H differential
Posted by Theman on January 21, 2009 at 10:02:33 from (63.107.135.35):
In Reply to: Farmall H differential posted by t martin on January 21, 2009 at 07:28:46:
The large ring gear should indeed be tight to the assembly. It doesn't have a key, pin, or spline. Bolt tension locks everything together. There should also be locking tabs under the nuts to prevent them from loosening once you get everything nice and tight. If the nuts don't snug up as you tighten them, then your bolts are failing and should be replaced.
