Farmall 656 hydraulics
Posted by Red Powerman on January 22, 2009 at 17:29:28 from (64.12.116.73):
I have a friend with a Farmall 656 gas tractor, every time you do something with the hydraulics the engine lugs down. Doesn't matter if you turn the steering wheel or use the remotes or the fast hitch. Almost sounds like theres a restricton some where. Hydraulic fluid is new HY tran and the filter is also new. Could it be a relief valve somewhere? It will drop the engine rpm about 500rpm which to me sounds like alot. Can you please help? Thank-You!
