Re: Farmall 656 hydraulics
Posted by bc on January 22, 2009 at 18:07:24 from (69.149.215.139):
In Reply to: Farmall 656 hydraulics posted by Red Powerman on January 22, 2009 at 17:29:28:
My 2606 will lug down and die if I don't wait until the engine and the fluid has warmed up or rev it way up. That's usually when I try to pickup the hoe off the ground which takes a lot of hyd. volume. Kinda have to keep it on partial choke till it is warm then it is ok. Now that I think about it, the stall point is when the cylinder has hit the end and it begins to bypass.
Don't know if it is the governor but it works when warmed up. I guess also once I have the loader and hoe off the ground, I can't drive in higher gear until completely warm without it dying. Maybe there is a governor issue when cold?
