Posted by Janicholson on January 24, 2009 at 06:43:25 from (68.112.156.69):
In Reply to: OT, plumbing posted by Bob S. on January 23, 2009 at 21:52:04:
IA Gary is on it. A small portion is now allowed in some areas. If you want the pipe T and El to be tight against the wall when tightened, it is best to put it together out side the wall and measure it (even with different fittings. Tightness and threading dies/taps have variations and allow differing depth of engagement. (as noted below) about 1/2" per joint is an average on Nominal 1/2" pipe. JimN
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
