Posted by NE IA on January 26, 2009 at 21:15:39 from (206.72.18.153):
In Reply to: Gasket Material posted by spiffy1 on January 26, 2009 at 18:22:09:
Some folks may think I'm crazy, but Blue RTV workes even better if you think on these terms.
Make your gasket out of the Blue RTV like normal. But do not tighten anything down, instead stick a small nail just in a tiny bit. Or use anything to keep it seperated a 1/8 th of a inch or even more in some cases. Let it dry for 24 hrs, remove nails, and then tighten it down. You now have a thicker compressed gasket that can take expansion or contraction.
If you tighten it down right away you basickly have little or no gasket left.
I learned this from a old mechanic, and seems to work well, and if you think about it it does make sence.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
