Re: 368293R91 Brake Actuator, F504, Issues... Pictures...
Posted by scotc on January 27, 2009 at 03:03:19 from (12.171.163.47):
In Reply to: Re: 368293R91 Brake Actuator, F504, Issues... Pictures... posted by charles todd on January 26, 2009 at 18:34:28:
If that's the same setup as the m/300/400, that rod should be something like a fine-threaded 7/16 bolt, with a few washers, a spring, that ball, then a nut to hold it all together so it stays together in the case of that bolt breaking. You should be able to grab whats left and spin it out with vice grips or channellocks and spin the new one in. The ones on my SM bend downward wherever I adjust them to. If you adjust them after use and the bolt it bent, make sure the bend is the same way when your done or it's off to the deler for another, sometime soon.
