I grew up on an H and Super A we pulled a HM150 3 disc plow with Hand a A151 2 disc plow with the Super A later had a 230 with a Fast hitch 2 disc plow and a Utility 330 with a fast hitch 3 disc plow we are in very rocky ground flint rock and limestone. we later pulled the HM 150 with a M. I have had the H turn around sideways when I hit a big rock just right. The disc plow gave way to bottom plows here when the trip bottoms and auto resets came out. Also to Offset plows. This is in Southwest MO.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
