Re: 368293R91 Brake Actuator, F504, Issues... Pictures...
Posted by Janicholson on January 28, 2009 at 06:33:38 from (199.17.6.128):
In Reply to: Re: 368293R91 Brake Actuator, F504, Issues... Pictures... posted by charles todd on January 27, 2009 at 19:25:39:
They are "clutch disks" they just stop instead of go. So the thickness should be determined to be OK if the geometry of the expandes is Ok. They do not do well in the last 1/4 of their travel, the pull links are at a steep angle and less effective. Some have found that the outer housing needs to be milled/ground to compensate for surface wear so new disks can be used with near original clearance and performance. Milling the mating surface of the outer housing brings the fixed friction surfaces closer together. JimN
