Re: Electronic Ignition
Posted by Janicholson on January 28, 2009 at 06:40:55 from (199.17.6.128):
In Reply to: Electronic Ignition posted by Chad504 on January 28, 2009 at 06:04:49:
Open the plug gap to ~.065 to .080 with a high output coil. As John T would say, if it goes out to the plug it came from the points (he would use more words like I usually do) The points would wear proportionatly more with a "hot" coil. The electronic ignition is designed to do it. Power improvement, yes on a dyno it might show a few % change, it is usually not seat of the pants unless the original ignition was toast. reliability hot spark for cold starts, and better consistant charge ignition all make them run better. JimN
