Posted by Chad504 on January 28, 2009 at 06:04:49 from (99.130.163.96):
So I'm sitting here, working from home again today. As an IT guy it's nice and quite right now, so I got to pondering some things. If I were to go to a Pertronics Electronic ignition in my H, with a 40K Volt Pertronics flamethrower coil, would I see a performance improvement? Assuming a 3/916 bore with Firecrater pistons and 130# compression? If I was to go this route with the ign and coil, what should I set the plug gap to? What about if I just change th ign first, should I open th plug gap? Also, if I replaced the coil should I change the gap, if keeping the points?
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
[More Ads]
