Posted by Jim Becker on January 28, 2009 at 07:50:51 from (71.252.139.51):
In Reply to: Electronic Ignition posted by Kevin_67_706 on January 28, 2009 at 06:04:49:
John,
You gave a good answer. But there is one more aspect of the question that should be added. As stated, the HV coil plus electronic switching allows you to open the plug gap for a fatter spark at higher voltage. However, an additional point is that the higher voltage is pushing the limits of the rest of the secondary system. The distributor and plug wires may cause problems when exposed to higher voltage. The probability of misfire or crossfire increase. If the higher operating voltage causes misfiring, you may loose power. Bottom line, the cap, rotor and wires need to be in top condition. Any dirt or oil inside the distributor will cause more trouble than at lower voltages.
Today's Featured Article - Upgrading an Oliver Super 55 Electrical System - by Dennis Hawkins. My old Oliver Super 55 has been just sitting and rusting for several years now. I really hate to see a good tractor being treated that way, but not being able to start it without a 30 minute point filing ritual every time contributed to its demise. If it would just start when I turn the key, then I would use it more often. In addition to a bad case of old age, most of the tractor's original electrical system was simply too unreliable to keep. The main focus of this page is to show how I upgr
... [Read Article]
Latest Ad:
[More Ads]
