Posted by Bob M on January 28, 2009 at 07:56:25 from (151.190.254.108):
In Reply to: Electronic Ignition posted by Chad504 on January 28, 2009 at 06:04:49:
I pretty much agree with JimN. A few comments however based on my experiences:
1 – If you open the plug gap make sure the plug wires, distributor cap and rotor are all in excellent (eg. “new”) condition and are scrupulously clean. Otherwise moisture, dust, etc. may cause arcing somewhere you don’t want and you'll get misfiring. (Keep in mind the stock cap, wires, etc are designed for only 15,000 – 20,000 volts max.)
2 – Don’t expect any noticable power improvement from the flamethrower coil. You MIGHT see a % or two on a dyno. But you’ll never feel it in use.
3 - At the RPMs and compression that your modified H engine will see, the stock 6 volt ignition system - IN GOOD SHAPE AND PROPERLY MAINTAINED - will be entirely adequate.
4 - The real advantage of electronic ignition is it is essentially maintenance-free. You'll no longer have to deal with weak spark, timing drift, etc. caused by point and rubbing block wear.
Today's Featured Article - Upgrading an Oliver Super 55 Electrical System - by Dennis Hawkins. My old Oliver Super 55 has been just sitting and rusting for several years now. I really hate to see a good tractor being treated that way, but not being able to start it without a 30 minute point filing ritual every time contributed to its demise. If it would just start when I turn the key, then I would use it more often. In addition to a bad case of old age, most of the tractor's original electrical system was simply too unreliable to keep. The main focus of this page is to show how I upgr
... [Read Article]
Latest Ad:
[More Ads]
