Re: Electronic Ignition
Posted by bc on January 29, 2009 at 09:39:49 from (69.149.215.139):
In Reply to: Electronic Ignition posted by Chad504 on January 28, 2009 at 06:04:49:
Just wondering what the cost is for an elec ign and hv coil?
Also poses another question. Would I see much of an improvement with an engine that has a fair amount of blowby and thus probably has lower compression and burns a little oil, maybe making the oil burn up better? On the other hand I can see where it only helps the mix in the cylinder on the compression stroke so it wouldn't do anything for blowby in the crankcase.
Thanks.
