Re: Transplanting 560/706/806 wide front ends onto an M...
Posted by rustyfarmall on January 31, 2009 at 07:24:16 from (207.199.225.86):
In Reply to: Transplanting 560/706/806 wide front ends onto an M... posted by waygull on January 31, 2009 at 00:27:00:
I would assume that it is, but I can't find the exact specs to say for sure. The clearance needed for the bigger tires would mostly depend on the backset of the wheels you choose. You need to determine the size of the tire you will be using, and then order a pair of wheels that will accommodate those tires.
