Re: Re: Re: Re: Super Charging
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Dave on April 05, 2000 at 09:37:17 from (128.113.2.58):
In Reply to: Re: Re: Re: Super Charging posted by maballance on April 05, 2000 at 08:01:44:
If it reads down slightly when running, that means it's either discharging while the tractor runs, or the ammeter is installed backwards. With the tractor off, turn on the lights. If it reads discharge, then the ammeter is installed properly. Turn the lights back off, and disconnect the field wire from the alternator. Start the tractor. The ammeter should read zero. If it still reads discharge, you have a ground. If it reads zero, then the reason for the discharge while the tractor runs is that the alternator field is using current, but the alternator isn't putting anything out to make up for what it's using. Could be as simple as a broken charging line from the alternator back to the battery, or it could be any of the reasons discussed in the posts above.
One more note: I don't know how well the alternator will take to being spun with no field current. On a generator, it is advised to remove the belt rather than run the generator "cold." The same may hold true for alts. I don't know, but it won't hurt to pull the belt while doing this to be safe.
Post A Followup
: Re: Re: Re: Re: Re: Super Charging
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
