Re: Re: Re: Re: Re: Super Charging
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Dave on April 05, 2000 at 10:50:13 from (128.113.2.25):
In Reply to: Re: Re: Re: Re: Super Charging posted by Dave on April 05, 2000 at 09:37:17:
One more note yet: Thinking about this further, I don't think the tractor will even run with no field to the alternator (it would if you had a gen&magneto like I do). Probably a better way to check is to see if there is any charging current flowing in the battery charging line from the alternator back to the ammeter and battery. You mentioned that you have 14 volts at the battery terminals when they are disconnected. This makes me think that you do have good voltage output from your alternator. Sounds to me like everything is working like it should, except for the mysterious discharge while the tractor is running. You could try the archives under "conversion" to read several years worth of discussion on this topic.
One personal bit of experience: 90% of electrical problems are caused by loose wires and dirt (which absorbs moisture and acts as a ground). Other than making sure everything is good and tight, and that you have continuity in all your wires, I'm out of ideas. Good luck.
Post A Followup
: Re: Re: Re: Re: Re: Re: Super Charging
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
