Scotty: Don't bet too heavily on that being cork. On my first snow blade I sheared one of those bolts at least three times per winter. Granted if you break them that often and remove the blade every summer, usually the broken bolt comes quite easy with a small chisel.
I have run across a couple of tractors with bolts rusted in there. I found drilling, easyout and ample supply of penetrating oil to be best solution.
I solved my problem by bracing my blade back to final drives.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
