IH Governor
Posted by mwilke on February 02, 2009 at 06:43:39 from (69.179.150.64):
I have a Super H and the throttle does not operate correctly. If I want speed up motor I have to pull throttle lever all the way back and adjust to desired speed. To slow down I have to push all the way forward then adjust to desired speed. Is there a spring inside the governor housing that needs to be replaced or am I needing to look elswhere for the problem?
Thanks for your help.
